[postgis-users] newbie GEOS install problem
Leif Isaksen l.isaksen at oxfordarch.co.uk
Fri Jul 28 07:17:43 PDT 2006
Hello
I'm trying to install GEOS on Suse 10.0 (64-bit) having already installed PostGIS. I'm having the following problem - ./configure runs OK, but the make command doesn't generate a proper libgeos.so file under source/geom/.libs (or rather it's a link to libgeos.so.2.2.3 which doesn't exist) leading to the following output:
Making all in bigtest
make[2]: Entering directory `/usr/local/geos-2.2.3/source/bigtest'
/bin/sh ../..//libtool --mode=link --tag=CXX g++  -g -O2   -o TestSweepLineSpeed  TestSweepLineSpeed.o GeometryTestFactory.o ../..//source/geom/libgeos.la ../..//source/geom/libgeos.la
g++ -g -O2 -o .libs/TestSweepLineSpeed TestSweepLineSpeed.o GeometryTestFactory.o  ../..//source/geom/.libs/libgeos.so
g++: ../..//source/geom/.libs/libgeos.so: No such file or directory
make[2]: *** [TestSweepLineSpeed] Error 1
make[2]: Leaving directory `/usr/local/geos-2.2.3/source/bigtest'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/geos-2.2.3/source'
make: *** [all-recursive] Error 1
leifsvm:/usr/local/geos-2.2.3 #
Is this because I already have PostGIS installed (and indeed, is it possible to install GEOS post-PostGIS)? I've tried to hunt down an RPM, as suggested on another email on the geos-devel mailing list, but there isn't one for Suse and the Fedora Core version seems to be a complete postGIS/GEOS package. I'm a little reluctant to reinstall PostGIS as I already have data stored in it, but will do so if necessary. Any help or suggestions on this issue would be gratefully received.
Best regards
Leif
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
