[postgis-users] all x point and y point
Alex Mayrhofer
axelm-postgis at nona.net
Mon Jun 5 22:12:39 PDT 2006
Patricio Cifuentes Ithal wrote:
> Hi,
> as I can know all points X,Y of a multiline, with function the postgis?
> my multiline is:
> SRID=-1;MULTILINESTRING((357495 6292952,357591 6292051,356671 6292396))
> I' need a list.:
> in row's
> 1. 357495 6292952
> 2. 357591 6292051
> 3. 356671 6292396
I'm using a function like this (might not be the most efficient one, and
does not work with MULTILINESTRING atm) - use dissect_line(geom):
--- dissects a line into its X,Y,(Z,M) values, returning a row per point
--- specific return type
CREATE TYPE dissect_line_ret AS
(x double precision, y double precision,
z double precision, m double precision);
--- function itself
CREATE OR REPLACE FUNCTION dissect_line (line geometry)
RETURNS SETOF dissect_line_ret AS $$
DECLARE
resultrow dissect_line_ret%ROWTYPE;
i integer;
npt integer;
pt geometry;
BEGIN
IF GeometryType(line) != 'LINESTRING' THEN
RAISE NOTICE 'dissect_line: cannot dissect a % geometry',
GeometryType(line);
RETURN;
END IF;
npt := NumPoints(line);
FOR i in 1..npt LOOP
pt := PointN(line,i);
resultrow.x := x(pt);
resultrow.y := y(pt);
resultrow.z := z(pt);
resultrow.m := m(pt);
RETURN NEXT resultrow;
END LOOP;
RETURN;
END;
$$ LANGUAGE plpgsql;
cheers
Alex
http://nona.net/features/map/
