RES: [postgis-users] How can I add geom column into a temporary table?
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Thu Jun 8 06:39:05 PDT 2006
Hello,
You can add it during the creation of the temporary table, just add
a field of type 'GEOMETRY'.
Ex:
CREATE TABLE "myTable" (
"gid" integer NOT NULL,
"geom" geometry
Gustavo
-----Mensagem original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Em nome de Fay Du
Enviada em: quarta-feira, 7 de junho de 2006 11:47
Para: postgis-users at postgis.refractions.net
Assunto: [postgis-users] How can I add geom column into a temporary
table?
Hi list:
I need to create a temporary table while I am running 4gl program. I
want to add geometry column into the table. And SELECT AddGeometryColumn
seems does not work for temporary table. How can I add this column into
the table? Many thanks for the help.
Fay
