[postgis-users] PL/PgSQL and PostGIS
Michael Fuhr
mike at fuhr.org
Sun Jun 11 06:06:38 PDT 2006
On Sat, Jun 10, 2006 at 05:00:26PM -0500, CYW wrote:
> CREATE OR REPLACE FUNCTION testxy(rtid integer, n integer) RETURNS text AS
> DECLARE
> rec RECORD;
> ptid integer;
> ptstr text DEFAULT 'default';
> cur CURSOR(key integer) FOR
> SELECT gid as ptid, AsText(geom) as point -- column gid is of int4 type
> FROM point_table WHERE guid=key ORDER BY measure ASC;
> psql:testpl.sql:45: ERROR: syntax error at or near "$1" at character 17
> QUERY: SELECT gid as $1 , AsText(geom) as point FROM point_table WHERE
> guid=$2 ORDER BY measure ASC
> CONTEXT: SQL statement in PL/PgSQL function "testxy" near line 18
> psql:testpl.sql:45: LINE 1: SELECT gid as $1 , AsText(geom) as point FROM
> point_table ...
> psql:testpl.sql:45: ^
You declared a variable named ptid; PL/pgSQL is trying to use it
where you wrote "gid as ptid", which results in a syntax error.
Use variable names that differ from other identifiers you need to
reference.
Michael Fuhr
