[postgis-users] PL/PgSQL and PostGIS
CYW
cyw at dls.net
Sat Jun 10 15:00:26 PDT 2006
Now trying the following script using Record:
CREATE OR REPLACE FUNCTION testxy(rtid integer, n integer) RETURNS text AS
DECLARE
rec RECORD;
ptid integer;
ptstr text DEFAULT 'default';
cur CURSOR(key integer) FOR
SELECT gid as ptid, AsText(geom) as point -- column gid is of int4
type
FROM point_table WHERE guid=key ORDER BY measure ASC;
BEGIN
OPEN cur(rtid);
FETCH cur INTO rec ;
CLOSE cur;
RETURN ptstr;
END;
$$ LANGUAGE plpgsql;
_____________________________________________________
I got the following errors while loading it:
psql:testpl.sql:45: ERROR: syntax error at or near "$1" at character 17
QUERY: SELECT gid as $1 , AsText(geom) as point FROM point_table WHERE
guid=$2 ORDER BY measure ASC
CONTEXT: SQL statement in PL/PgSQL function "testxy" near line 18
psql:testpl.sql:45: LINE 1: SELECT gid as $1 , AsText(geom) as point FROM
point_table ...
psql:testpl.sql:45: ^
______________________________________________________
The error message is not very informative to me. What am I doing wrong?
Thanks a bunch.
cyw
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Michael
Fuhr
Sent: Saturday, June 10, 2006 7:26 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PL/PgSQL and PostGIS
On Sat, Jun 10, 2006 at 01:30:19AM -0500, CYW wrote:
> I am trying a PL/PgSQL script below, and getting the following error:
> invalid input syntax for integer: "Point(111.000 999.22)"
> Context: PL/pgSQL function "testxy" line # 12 at fecth
> Any suggestions?
> CREATE OR REPLACE FUNCTION testxy() RETURNS text AS $$
> DECLARE
> thisrow point_table%ROWTYPE;
> rid integer DEFAULT 1;
> msg text;
> cur CURSOR(key integer) FOR SELECT AsText(geom) as geom
> FROM point_table WHERE guid=rid ORDER BY measure ASC;
> BEGIN
> OPEN cur(rid);
> FETCH cur INTO thisrow ;
You've declared thisrow to be point_table%ROWTYPE, which is presumably
something like (integer, ..., geometry). The cursor's select list
has a single text column; FETCH INTO is trying to store that text
column in thisrow's first column (an integer) so you get a type
mismatch. Declare thisrow to be of type record, or declare it to
be text and return thisrow instead of thisrow.geom. Examples:
DECLARE
thisrow record;
or
DECLARE
thisrow text;
RETURN thisrow;
Michael Fuhr
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
