[postgis-users] Installation postGIS1.1.2
Frank Koormann frank.koormann at intevation.de
Mon Jun 12 03:26:28 PDT 2006
* Stüwe Rolf <Rolf.Stuewe at stadt.wuppertal.de> [060612 12:05]:
> Hello,
> I have a problem by installing postgis 1.1.2 with postgres 8.1.4 under
> Suse linux /9 64 bit Version.
> It seems that the configure and make Skript does not find the right
> path of the postgres-Version.  For using the configure-Skript I have
> to set the PATH on the postgres ... pg_config-file.  after this the
> "make" does not find some files, that are in the right path of the
> postgres installation (postgres.h or geo_decls.h).  geos2.2.2 and
> proj4 4.4.9 are installed correctly, the postgis is correctly under
> the postgres/contrib path.  Is it possible, that the versions are not
> compatibel?
I have a combination of PostgreSQL 8.1.4 with PostGIS 1.1.2 sucessfully
running on SLES9. Can you please elaborate a bit more your setup, i.e.
- ./configure call for PostgreSQL
- ./configure call for PostGIS
- output of the PostGIS - make
Best regards,
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professioneller Service um Freie Software        (http://intevation.de/)
 FreeGIS Projekt                                  (http://freegis.org/)
 PostGIS Support     (http://intevation.de/services/gis/postgis.de.html)
