AW: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
Stüwe Rolf
Rolf.Stuewe at stadt.wuppertal.de
Mon Jun 12 06:17:49 PDT 2006
I think it i sa problem with the paths:
the configure of postgres is :
LDFLAGS=-lstdc++ ./configure --prefix=/usr1/postgres/pgsql_814 --without-zlib
and all paths are correct in the log-files
(I want to install in /usr1/postgres/pgsql_814 instead of /usr/local)
the configure if postGIS is:
./configure --with-pgsql=/usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config/pg_config
but the summary says :
PORTNAME: linux
PREFIX: /usr1/postgres/pgsql814
EPREFIX: ${prefix}
DOC: /usr1/postgres/pgsql814/doc/contrib
DATA: /usr1/postgres/pgsql814/share/contrib
MAN: /usr1/postgres/pgsql814/man
BIN: /usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config
EXT: /usr1/postgres/pgsql814/lib (\$$libdir)
the path from postGIS is not ...pgsql_814 but ...pgsql814. This is the path of a former compilation, but it is not actual,
I did the next compilation with ...pgsql_814 and did a "make clean" before and removed the old, wrong directory.
Where can postGIS remembered the older, wrong path
with regards
Rolf
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von strk at refractions.net
Gesendet: Montag, 12. Juni 2006 12:08
An: postgis-users at postgis.refractions.net
Betreff: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
On Mon, Jun 12, 2006 at 12:05:00PM +0200, Stüwe Rolf wrote:
> Hello,
> I have a problem by installing postgis 1.1.2 with postgres 8.1.4 under Suse linux /9 64 bit Version.
> It seems that the configure and make Skript does not find the right path of the postgres-Version.
> For using the configure-Skript I have to set the PATH on the postgres ... pg_config-file.
You shoul not need that, --with-pgsql=path/to/pg_config should do.
If you still have problem please include the errors and warnings you're getting in each phase of the build.
--strk;
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
