[postgis-users] problems running lwpostgis.sql - undefined symbol: nth
Jessica M Salmon
jmsalmon at fs.fed.us
Wed Jun 14 10:03:20 PDT 2006
Have you tried
echo /usr/local/lib/ >> /etc/ld.so.conf
ldconfig -v
Brian Caruso
<bdc34 at cornell.ed
u> To
Sent by: PostGIS Users Discussion
postgis-users-bou <postgis-users at postgis.refractions.
nces at postgis.refr net>
actions.net cc
Subject
06/14/2006 10:55 Re: [postgis-users] problems
AM running lwpostgis.sql - undefined
symbol: nth
Please respond to
PostGIS Users
Discussion
stgis.refractions
.net>
Thanks for the advice but the issue still looms.
sherman wrote:
> Did you run:
> createlang plpgsql yourtestdatabase
> on your database prior to running the lwpostgis.sql script?
I did execute that command and it seems to have been successful.
Just to make sure I dropped my test database, created a new one,
ran this command then got the same error as before.
strk wrote:
> Try make clean, the library seems built for a different PostgreSQL
version.
I did that and got the same result:
psql:/usr/local/src/postgresql-8.1.4/contrib/postgis-1.1.2
/lwpostgis.sql:51:
ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.1":
/usr/local/pgsql/lib/liblwgeom.so.1.1: undefined symbol: nth
I've been configuring postgis with --prefix='/usr/local/pgsql' as that
is where postgres got installed. Is that the correct thing to do? If I
don't do this I get a message when running lwpostgis.sql that
liblwgeom.so.1.1 cannot be found.
Brian Caruso
Programmer/Analyst
Albert R. Mann Library
Cornell University
Ithaca, NY 14853
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
