[postgis-users] polygons crossing 0/360 longitude
Shane Byrne shane at quake.mit.edu
Wed Jun 21 08:41:50 PDT 2006
ok
I was thinking more of that polygon (170 20, -170 20, 175 5, 170 10, 170
20) becoming:
Polygon 1:
170 20, 180 20, 180 10, 175 5, 170 10, 170 20
Polygon 2:
-180 20, -170 20, -180 10
i.e. introducing two new vertices on the dividing meridian and having
the area of the two polygons add up to the total area of the original.
It sounds like there is no easy way to do this in PostGis though. I
think your approach of using perl to figure it out would probably be the
   easiest way.
My polygons are pretty simple and only cross the meridian once, I guess
a complicated polygon could do that several times which will confuse things.
Cheers,
Shane
Carlos Ferrão wrote:
> To calculate the two polygons I am using a PERL script on data
> ingestion to build the insert statement..
> If I have a polygon which is (lon/lat)
> 170 20, -170 20, 175 5, 170 10, 170 20
> it becomes
> polygon 1:
> 170 20, (-170+360=190) 20, 175 5, 170 10, 170 20
> polygon 2:
> (170-360=-190) 20, -170 20, (175-360=-185) 5, (170-360=-190) 10,
> (170-360=-190) 20
> Just insert the two polygons into a single row using the MULTIPOLYGON
> object.
> Carlos.
> On 6/21/06, Shane Byrne <shane at quake.mit.edu> wrote:
>> Thanks Carlos, this is a good idea.
>> Finding the problem polygons is easy enough, but how did you split them
>> into two polygons along this meridian? Can I define a line and with that
>> use some postgis function to split the polygon?
>> I'd also like to copy over all the information in the other fields to
>> each new polygon.
>> Shane
>> > Hi,
>> > I recently had a similar problem with products crossing the -180/180
>> > longitude. The problem is that postgis doesn't connect the -180 to the
>> > 180 as, for instance, Oracle Spatial Module.
>> > The way I found to solve it was to do an algorithm to find the
>> > polygons that cross the date line. For each one, I calculate 2
>> > polygons, one in the negative coordinates and another in the positive
>> > coordinates (you need to add/subtract 360). I add a multipolygon with
>> > the information of the two polygons in a single row in the database
>> > and it works perfectly.
>> > Hope it helps,
>> > Carlos Ferrao
>> > EOP - ESRIN - European Space Agency
>> > Critical Software - www.criticalsoftware.com
>> >> Hi,
>> >> I have a postgres/postgis database with many (~80k) polygons, the
>> >> vertices of which are stored in longitude (0-360) and latitude space.
>> >> These polygons are typically small, but a few hundred of them span the
>> >> prime meridian. This creates a problem for me when I search for
>> polygon
>> >> intersections. i.e. a polygon with a longitude range -5 to +5 is
>> >> actually stored as +355 to +5 and so postgis thinks it intersects a
>> >> whole bunch of polygons that it really doesn't.  I could change to the
>> >> -180 to 180 longitude system but that only moves the problem to a
>> >> different longitude.
>> >> Is there a graceful way around this?
>> >> I'm thinking of just making two tables, the other table would have
>> >> longitudes ranging from -180 to +180 and doing two searches with
>> >> longitude ranges chosen to avoid the problem area on each table. Does
>> >> postgis have a way to handle cyclical coordinates?
>> >> Thanks for any help,
>> >> Shane
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> ______________________________________________________________
>> Shane Byrne  -  University of Arizona  - Lunar & Planetary Lab
>> Email: shane at lpl.arizona.edu              Phone: (928)556-7235
>> Web  : http://www.gps.caltech.edu/~shane  Fax  : (928)556-7014
>> Mail : USGS - Astrogeology Division,
>>         2255 North Gemini Drive, Flagstaff, AZ 86001, US.
