[postgis-users] >2D rectangular predicates?
Chris Nicholas
cgnicholas at alamedanet.net
Thu Jun 22 10:14:56 PDT 2006
hmmm - perhaps the straight "@", "~", and "&&" will just work with 3D
boxes..? that would be way cool...
Chris
Chris Nicholas wrote:
> Hi - I was wondering whether the underlying GiST, etc mechanisms might
> support >2D bounding box queries efficiently... I really want to do
> fast queries againt BIG tables like :
> select foo from stuff where CONTAINS( <3/4D bounding box>, the_geom),
> now, I realize one might do a subselect in 2D, and then proceed with
> measures, but I'm intrigued by the "cube" stuff I'm seeing in
> contrib/cube, and wondering if I might use non-cubic rectangular
> regions instead.
> thanks in advance for any words of wisdom, RTFMs, etc.
> Chris
> [postgis-users] 3d Points
> *strk at refractions.net * strk at refractions.net
> <mailto:postgis-users%40postgis.refractions.net?Subject=%5Bpostgis-users%5D%203d%20Points&In-Reply-To=C8EC7AEB-A485-43B3-98EB-329DFD806870%40geosci.usyd.edu.au>
> /Mon Aug 1 11:07:50 PDT 2005/
> * Previous message: [postgis-users] 3d Points
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/008836.html>
> * Next message: [postgis-users] 3d Points
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/008858.html>
> * *Messages sorted by:* [ date ]
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/date.html#8838>
> [ thread ]
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/thread.html#8838>
> [ subject ]
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/subject.html#8838>
> [ author ]
> <http://postgis.refractions.net/pipermail/postgis-users/2005-August/author.html#8838>
> On Mon, Aug 01, 2005 at 07:47:38PM +1000, Christian Heine wrote:
>> / Is it advisable to use EWKT or is it better to create an extra z-
> />/ value column and keep the z-value separated from the lon/lat?
> You don't loose anything using the extra Z-value column, you
> can always extract 2d-version or OGC-standard representation from
> a 3d object.
>> / Also,
> />/ what is the difference between POINTM and POINT? I couldn't find
> any />/ information explaining the "M".
> "M" stand for "Measured". It's an additional coordinate you can use
> for time or rilevated distance or whatever other parameter you
> can associate to a vertex of your geometry.
> In PostGIS we use the M suffix to specify that the
> tree dimensions given are X,Y,M instead of X,Y,Z.
> Examples:
> POINT(0 0) <---- X,Y (2D)
> POINT(0 0 0) <---- X,Y,Z (3DZ)
> POINTM(0 0 0) <---- X,Y,M (3DM)
> POINT(0 0 0 0) <---- X,Y,Z,M (4D)
> Distinction between 3DZ and 3DM is there to store
> semantic of the third parameter. Some operations
> would compute an appropriate value for the 3rd
> dimension if and only if it is a Z (and not an M).
> --strk;
> postgis-users mailing list
