[postgis-users] update / closest polygon
Josh Livni josh at livniconsulting.com
Fri Mar 3 12:58:28 PST 2006
Adam,
Thanks a lot for the response.  I only need to the distance query once, but
in any case, I unfortunately was unable to get your query to run.  I am no
expert with this type of join, and I kept running into a 'ERROR: missing
FROM-clause entry for table "polygons"' (or table centroids if I added
polygons to the from clause).
In any case, I will continue to research my options, but if anyone has a
followup for what is probably a simple question to most of you (find the
closest polygon to a given set of points), I would certainly appreciate.
I think my alternative now is to just use a python script and psycopg, and
query for the closest polygon each point at a time, and update one at a
time.  This would be quite slow...
Thanks again,
  -Josh
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Adam
Quiney
Sent: Friday, March 03, 2006 10:42 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] update / closest polygon
Hi Josh,
Though you could probably achieve this using nested queries, computing
distance to and from each of your points/polygons could be an expensive
operation.  If this operation will be performed more than once, then I
would be inclined to create a table holding the distances between your
points and polygons, then indexing based on this distance:
CREATE TABLE poly_point_distance AS
SELECT c.centroid_id, p.polygon_id, distance(c.centroids.the_geom,
p.polygons.the_geom) AS pp_distance
FROM polygons AS p
INNER JOIN centroids AS c
	ON expand(centroids.the_geom,1000) && polygons.the_geom
	AND distance(centroids.the_geom, polygons.the_geom) < 1000
CREATE INDEX distance_idx ON poly_point_distance (pp_distance);
You would probably want to create indices on the foreign keys in this
table as well.
The above query may be able to be optimized, this is just a quick jot.
You can then perform a join against this table during your update to
pull out the minimum distance.
--Adam
Josh Livni wrote:
>  I have a basic 'update' question.  For a simple example, given a bunch
> of points, I'd like to give them attributes based on the closest polygon.
> Let's say I try this:
> UPDATE centroids
> SET p_distance = distance(centroids.the_geom, polygons.the_geom),
> FROM polygons
> WHERE expand(centroids.the_geom,1000) && polygons.the_geom
>   and Distance(centroids.the_geom, polygons.the_geom) < 1000
> This associates any polygon within 1k to the point -- but not
> necessarily the closest.  Is there an easy way to bring in an 'order by
> distance' and 'limit 1' kind of idea to the UPDATE query?  Do I need to
> do that in a separate select, make a temp table, and then join?
> Thanks in advance for any pointers.
>   -Josh
> postgis-users mailing list
Adam Quiney
Refractions Research Inc.
aquiney at refractions.net
(250) 383-3022
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.375 / Virus Database: 268.1.2/274 - Release Date: 3/3/2006
No virus found in this outgoing message.
