[postgis-users] update / closest polygon
David Bitner
osgis.lists at gmail.com
Fri Mar 3 13:43:06 PST 2006
Off the top of my head, I can't quite remember if you can throw an
aggregate into an update statement like this, but have you tried:
UPDATE centroids
SET p_distance = min(distance(centroids.the_geom, polygons.the_geom)),
FROM polygons
WHERE expand(centroids.the_geom,1000) && polygons.the_geom
and Distance(centroids.the_geom, polygons.the_geom) < 1000
On 3/3/06, Josh Livni <josh at livniconsulting.com> wrote:
> I have a basic 'update' question. For a simple example, given a bunch
> of points, I'd like to give them attributes based on the closest polygon.
> Let's say I try this:
> UPDATE centroids
> SET p_distance = distance(centroids.the_geom, polygons.the_geom),
> FROM polygons
> This associates any polygon within 1k to the point -- but not
> necessarily the closest. Is there an easy way to bring in an 'order by
> distance' and 'limit 1' kind of idea to the UPDATE query? Do I need to
> do that in a separate select, make a temp table, and then join?
> Thanks in advance for any pointers.
> -Josh
> postgis-users mailing list
