[postgis-users] ogr2ogr error message for Tiger to PostgreSQL conversion
Timsy Bir timsy.bir at gmail.com
Sat Mar 4 16:46:04 PST 2006
Hi
I am trying to parse the Tiger data to a database. Someone recommended the
ogr2ogr tool, and I tried this:
  ogr2ogr -f "PostgreSQL" PG:dbname=mingle03 TGR08021.RT1
but got the error:
  ERROR 3: Failed to read record 500 of TGR08021.RT5
  ERROR 1: INSERT command for new feature failed.
  ERROR:  invalid UTF-8 byte sequence detected near byte 0xa2
  Command: INSERT INTO "polygon" ("module", "file", "cenid", "polyid",
"tract", "blocksufcu", "rs_a1", "aianhhfpcu", "aianhhcu", "aihhtlicu",
"anrccu", "aitscecu", "aitscu", "concitcu", "cousubcu", "sdelmcu",
"sdseccu", "sdunicu", "msacmsacu", "pmsacu", "necmacu", "rs_a5", "rs_a6",
"rs_a7", "rs_a8", "rs_a11", "rs_a13", "state", "aianhh", "aihhtli",
"aitsce", "aits", "cousub", "submcd", "place", "sdelm", "sdsec", "sduni",
"msacmsa", "cd106", "cd108", "puma5", "puma1", "zcta5", "zcta3", "taz",
"ua") VALUES ('TGR08021', 8021, 'C1506', 2, 92071, '9', '7', 47001, 93, '3',
3, 0, 501, 0, 5100, '    0', '8021', '
', 0, 0, 0, ',¢', '¿.£', '
                          ·Ðo', ', '~¢¿', 'Àð·', 0, 802, '1', 920, 71, 974,
70010, 59, 5, 0, 1, 6, 0, 81, 140, 0, '02080', '21C', '1506', 30)
  ERROR 1: Terminating translation prematurely after failed translation of
layer Polygon
Any suggestions on how to solve this? The postgis.sql and
spatial_ref_sys.sql scripts are loaded onto the database, but other than
that, no tables have been set up. I am a beginner and would appreciate any
suggestions or pointers.
Thanks for your help.
Sincerely,
Timsy Bir
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060304/dc7cd263/attachment.html>
