[postgis-users] TopologyException : another example.
strk at refractions.net
Sun Mar 5 11:36:56 PST 2006
On Fri, Mar 03, 2006 at 06:21:15PM +0100, Guillaume Sueur wrote:
> Hi list,
> I think I've got a good example of TopologyException too.
> I try to aggregate my cities boundaries on a district field to get
> districts boundaries. The geom of cities is valid (set as a constraint).
> When I run the simple query "CREATE TABLE districts as SELECT
> iddistrict, geomUnion(the_geom) from cities, if gives back :
> NOTICE: TopologyException: no outgoing dirEdge found (436814,2.01401e+06)
> ERROR: GEOS union() threw an error!
> Taken individually, my district build fine until some specific case :
> when a city and another one to merge with are only sharing one point. I
> think the module tries to do a unique shape then, which gives a non vaid
> geometry, instead of building two distinct parts.
> What do you think ?
Can you try building a small testcases illustrating your assumption, or
showing the exact bug you're running into ?
If geomunion returns an invalid geometry, that'd be a bug.
--strk;
