[postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0. 9 toPostgreSQL 8.1 with PostGIS 1.0
Mario Servin mservin at gmail.com
Sun Mar 5 14:08:24 PST 2006
Paul,
Does it mean I will never get from (for example) PGAdmin III a table view of
my geometry data in human readable format?
Sometimes it is so easy to change values directly in the view...
Mario
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, January 20, 2006 1:48 PM
Subject: Re: [postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0. 9
> Actually, the data is *stored* in a C struct, what you see when you  type
> "select geom from mytable" is the "canonical representation" of  the
> geometry.  The canonical representation used to be "well known  text"
> (WKT) which has the advantage of being human readable.  The  trouble is,
> the canonical representation is used for things like  database backup dump
> files, and really is spit out any time any  client asks for the geometry.
> That means the data is constantly  going from the internal binary form to
> text to binary, and so on.   This can cause very small drifts in the
> values, which means that it  was possible to backup a database table,
> restore it, and find that  the geometries were no longer exactly the same.
> They were not *very*  different, but they were a little different.
> In general, using the OGC standard representation functions (astext,
> asbinary) is what people should do when pulling information out of  the
> database.  Mapserver's PostGIS support (mappostgis.c) did this,  and as a
> result when we changed the canonical form (and the on-disk  form as well)
> for 1.0 mapserver remained compatible with the new  versions of postgis,
> despite very very substantial changes to postgis.
> Paul
> On Jan 20, 2006, at 8:22 AM, Sears, Jeremy wrote:
>> >>Unfortunately the geom column of my data again appear as a
>> strange string of characters where I expected to see something as  POINT,
>> LINE etc.
>> I asked the same question and was informed that this is normal. You  data
>> should look like incoherent strings. Apparently this is how  the data are
>> stored in newer versions of postgis.
>> Glad to help
>> Jeremy
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
>> users-bounces at postgis.refractions.net]On Behalf Of Mario Servin
>> Sent: January 20, 2006 11:01 AM
>> To: PostGIS Users Discussion
>> 0. 9 to PostgreSQL 8.1 with PostGIS 1.0
>> Thanks Jeremy. I used that and now postgis_restore works to the  end.
>> Unfortunately the geom column of my data again appear as a  strange
>> string of characters where I expected to see something as  POINT, LINE
>> etc. I do not know what else can I do .....
>> On 1/20/06, Sears, Jeremy <Jeremy.Sears at ccrs.nrcan.gc.ca> wrote:
>> >>The postgis_restore.pl could create the dump list and also the
>> dump ascii but then gives an error because it does not allow me to  write
>> down the password at the next >>step.
>> I was having a simmilar problem. Each time I'd run  postgis_restore.pl It
>> would promt for my password 3 time before  bailing, indicating that the
>> password was incorrect. It was pointed  out to me that this can be
>> avoided by setting the following  environment variables, PGUSER and
>> PGPASSWORD. I also found it  useful to specify PGHOST, PGPORT, and PGDATA
>> as well. You can set  the env variable at the cmmd prompt like this:
>> >set PGUSER=username
>> or you can set the in controlpanel-->system-->advanced-->
>> hope that helps
>> Jeremy
>> users-bounces at postgis.refractions.net ]On Behalf Of Mario Servin
>> Sent: January 20, 2006 10:06 AM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS  0.9
>> Hi everybody,
>> I failed completely to restore my data from a PostgreSQL 8.0 with
>> PostGIS 0.9 to PostgreSQL 8.1 with PostGIS 1.0. I have both  versions of
>> PosgreSQL running in Windows. I follow instructions in  PostGIS docs from
>> the PostgreSQL installation for upgrading. The  postgis_restore.pl could
>> create the dump list and also the dump  ascii but then gives an error
>> because it does not allow me to write  down the password at the next
>> step. As I know something about Perl  I tried to modify the script
>> without success.
>> Additionally, I still have the results from the old shp2pgsql and  so I
>> tried to insert the data form psql using \i  mysqlinsertionscript.sql.
>> Tables are created ok, but geom columns  results in meaningless
>> characters where it is supossed to be  something like "POINT (-
>> 66.046532 -21.951437)" for example.
>> Can anybody help me?.
>> Regards,
>>             Mario Servin
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
