[postgis-users] polygonize line strings
Michael Fuhr
mike at fuhr.org
Sun Mar 5 19:58:05 PST 2006
On Fri, Mar 03, 2006 at 03:55:00AM -0700, Michael Fuhr wrote:
> On Fri, Mar 03, 2006 at 09:58:30AM +0100, Bart van den Eijnden (OSGIS) wrote:
> > Can this data be polygonized with PostGIS? If so how can this be done?
> Is the following close to what you're looking for? If not then
> maybe I've misunderstood.
> SELECT perceel, polygonize_garray(accum(geom)) AS geom
> FROM (
> SELECT perceel_li AS perceel, geom FROM foo
> UNION ALL
> SELECT perceel_re AS perceel, geom FROM foo
> ) AS s
> GROUP BY perceel;
Or perhaps
SELECT perceel, polygonize(geom) AS geom FROM ....
The main idea, if I understand what you're after, is the union.
Below is a complete example using the following geometries (best
viewed with a fixed-width font):
15 +-------+
10 | A +-------+
5 +-------+ C |
| B | |
0 +-------+-------+
0 10 20
CREATE TABLE foo (
id serial PRIMARY KEY,
p_li char,
p_re char
SELECT AddGeometryColumn('foo', 'geom', -1, 'LINESTRING', 2);
INSERT INTO foo (p_li, p_re, geom) VALUES (NULL, 'A', 'LINESTRING(0 15,10 15)');
INSERT INTO foo (p_li, p_re, geom) VALUES (NULL, 'A', 'LINESTRING(10 15,10 10)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('C', 'A', 'LINESTRING(10 10,10 5)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('B', 'A', 'LINESTRING(10 5,0 5)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('A', NULL, 'LINESTRING(0 15,0 5)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('C', 'B', 'LINESTRING(10 5,10 0)');
INSERT INTO foo (p_li, p_re, geom) VALUES (NULL, 'B', 'LINESTRING(10 0,0 0)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('B', NULL, 'LINESTRING(0 5,0 0)');
INSERT INTO foo (p_li, p_re, geom) VALUES ('C', NULL, 'LINESTRING(20 10,10 10)');
INSERT INTO foo (p_li, p_re, geom) VALUES (NULL, 'C', 'LINESTRING(20 10,20 0)');
INSERT INTO foo (p_li, p_re, geom) VALUES (NULL, 'C', 'LINESTRING(20 0,10 0)');
SELECT p, AsText(polygonize(geom)) AS geom
FROM (
SELECT p_li AS p, geom FROM foo WHERE p_li IS NOT NULL
UNION
SELECT p_re AS p, geom FROM foo WHERE p_re IS NOT NULL
) AS s
GROUP BY p
ORDER BY p;
p | geom
A | GEOMETRYCOLLECTION(POLYGON((0 5,0 15,10 15,10 10,10 5,0 5)))
B | GEOMETRYCOLLECTION(POLYGON((0 0,0 5,10 5,10 0,0 0)))
C | GEOMETRYCOLLECTION(POLYGON((10 0,10 5,10 10,20 10,20 0,10 0)))
(3 rows)
You could use GeometryN() to get just the polygon.
Is this anything like what you're trying to do?
Michael Fuhr
