[postgis-users] installing postgis in Ubuntu 5.10(Breezy)
Blair Zajac
blair at orcaware.com
Tue Mar 7 10:34:08 PST 2006
On Mar 7, 2006, at 10:30 AM, Mikael Schröder wrote:
> Hi all!
> I followed this thread and read every thing I could find on the
> matter, but when I try to add the PostGIS 8.1 deb from within
> Synaptic in Breezy, Synaptic complains about wrong version of
> libstdc (4.0.1 instead of 4.0.2) and consequently libgeos2c2. How
> can I handle this problem without compiling from source or changing
> to next version of libstdc wich I understand to be a bit
> bothersome. Does anyone have a different pkg for breezy?
> /Mikael
> >I appreciate your help, but I think you are working in unstable
> with >libstdc++ 4.02 and I'm in Breezy with libstdc++4.01. If
> Blair can fix >his pkg then that gives Breezy users both postgresql
> 8.1 & postgis.
What issue are you seeing? The packages I built are only built
against Breezy's packages. I make all the packages I built available
in my site, so there shouldn't be any dependencies that are not
fullfilled.
Also, shouldn't 4.01 and 4.02 be binary compatible?
Regards,
Blair
Blair Zajac, Ph.D.
<blair at orcaware.com>
Subversion training, consulting and support
http://www.orcaware.com/svn/
