[postgis-users] PostGIS without JTS or GEOS
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Wed Mar 15 03:51:55 PST 2006
My version is:
POSTGIS="1.0.0" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
Thanks for the command.
Sincerely...
Ezequias
Nicolas Ribot escreveu:
>>  Hi list,
>>  Here at the work we are trying to make some spatial operations on our GIS
>> database, but when we try to generate functions like:
>> "SELECT desc,address,picture,asText(geometry) AS geometry
>> FROM tab1"
>> This function works but this one:
>> SELECT PointOnSurface(geometry) FROM tab1
> Hi,
> You should install postgis + geos :-)
> What is your postgis version, given by:
> select postgis_full_version() ?
> Nicolas
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
