> POSTGIS="1.0.0" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0" > > Thanks for the command. > It appears you don't have geos installed. You should read the doc or search the mailing list to see how to install geos on an existing postgis database (I personnaly always install postgis + geos at the same time) Nicolas
