[postgis-users] joining geometry and data tables
Klingseisen Bernhard
Bernhard.Klingseisen at arcs.ac.at
Mon Mar 20 00:54:34 PST 2006
I'm a newby on postgis and have some troubles to join an attribute table
to a geometry table. If I use the the SQL example from the wiki, it
seems to me that I dont get the full postgis support.
CREATE TABLE jointest AS (
SELECT p.zip as plz3, d.count_1 as count, p.the_geom as the_geom
FROM plz_austria p
LEFT JOIN wassercheck2005_ges d ON d.gid = p.plz
The resulting table looks quite different in pg admin to a table that I
natively import to postgis using the shape loader:
Table generated with the above sql statement:
-- Table: jointest
-- DROP TABLE jointest;
plz3 int2,
count numeric,
the_geom geometry
WITHOUT OIDS;
ALTER TABLE jointest OWNER TO wasserinfo06;
Original geometry table containg zip code area of Austria:
-- Table: plz_austria
-- DROP TABLE plz_austria;
CREATE TABLE plz_austria
gid int4 NOT NULL DEFAULT nextval('plz_austria_gid_seq'::regclass),
name varchar(50),
plz int4,
zip int2,
the_geom geometry,
CONSTRAINT plz_austria_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 31297)
WITHOUT OIDS;
ALTER TABLE plz_austria OWNER TO wasserinfo06;
-- Index: plz_austria_the_geom_gist
-- DROP INDEX plz_austria_the_geom_gist;
CREATE INDEX plz_austria_the_geom_gist
ON plz_austria
USING gist
(the_geom);
Apparently this result is not right, because I cannot display it in
mapserver or udig.
Which additions do I need in the SQL statement to generate all the
additional constraints and indexes? Any help is much appreciated.
Kind Regards
Bernhard
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060320/6b955e8b/attachment.html>
