[postgis-users] joining geometry and data tables
Brent Wood
pcreso at pcreso.com
Mon Mar 20 01:20:31 PST 2006
--- Klingseisen Bernhard <Bernhard.Klingseisen at arcs.ac.at> wrote:
> I'm a newby on postgis and have some troubles to join an attribute table
> to a geometry table. If I use the the SQL example from the wiki, it
> seems to me that I dont get the full postgis support.
I have one suggestion,
If you create the gepmetry attribute like this, then Postgis won't generate the
record in the geometry_columns table which stores information about the
geometries in the database (which is read by mapserver).
Create your table first as described in the Postgis docs:
CREATE TABLE jointest (plz3 integer,
count_ integer);
SELECT ADDGEOMETRYCOLUMN (see the postgis docs for the proper use of this
command) ;
then-
INSERT INTO jointest
SELECT p.zip,
d.count_1,
p.the_geom
FROM plz_austria p
LEFT JOIN wassercheck2005_ges d ON d.gid = p.plz;
This will result in a table with a geometry attribute which can be used by
mapserver (it will be recorded in the geometry_columns table)
Cheers,
Brent Wood
> CREATE TABLE jointest AS (
> SELECT p.zip as plz3, d.count_1 as count, p.the_geom as the_geom
> FROM plz_austria p
> The resulting table looks quite different in pg admin to a table that I
> natively import to postgis using the shape loader:
> Table generated with the above sql statement:
> -- Table: jointest
> -- DROP TABLE jointest;
> plz3 int2,
> count numeric,
> the_geom geometry
> WITHOUT OIDS;
> ALTER TABLE jointest OWNER TO wasserinfo06;
> Original geometry table containg zip code area of Austria:
> -- Table: plz_austria
> -- DROP TABLE plz_austria;
> CREATE TABLE plz_austria
> gid int4 NOT NULL DEFAULT nextval('plz_austria_gid_seq'::regclass),
> name varchar(50),
> plz int4,
> zip int2,
> the_geom geometry,
> CONSTRAINT plz_austria_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 31297)
> WITHOUT OIDS;
> ALTER TABLE plz_austria OWNER TO wasserinfo06;
> -- Index: plz_austria_the_geom_gist
> -- DROP INDEX plz_austria_the_geom_gist;
> CREATE INDEX plz_austria_the_geom_gist
> ON plz_austria
> USING gist
> (the_geom);
> Apparently this result is not right, because I cannot display it in
> mapserver or udig.
> Which additions do I need in the SQL statement to generate all the
> additional constraints and indexes? Any help is much appreciated.
> Kind Regards
> Bernhard
> postgis-users mailing list
