[postgis-users] shp2pgsql options?
Amit Kulkarni
amitkulz at yahoo.com
Mon Mar 20 12:59:39 PST 2006
If you see the postgis view, and the .sql file the gid is defined as a
unique serial.
Or you could do a
1) list shapefiles via ls
2) open each shapefile with a shell/batch script and replace END; with
CREATE INDEX [SHP_name] ON [SHPTBL] ( oid );
END;
HTH
Hello,
I've been trying to load a set of shapefiles into a PostgreSQL 8.1.1 +
PostGIS 1.1.0 database and having a bit of trouble with missing "oids".
I've read that the current PostgreSQL doesn't create tables with OID by
default, but they are required for use with MapServer. Due to that, my
load process becomes:
shp2pgsql -p -I -s <EPSG> shapefile.shp tablename >tablename_create.sql
vi tablename_create.sql
add "WITH OIDS" to the "CREATE TABLE" command
psql -d database -f tablename_create.sql
shp2pgsql -a -s <EPSG> shapefile.shp tablename | psql -d database
That's a bit of a pain when dealing with hundreds of shapefiles. Is
there an option for shp2pgsql (maybe "-O") that would tell it to create
the tables with OIDS?
Thanks,
Thom
Thom DeCarlo
there was coffee.
life would go on.
william gibson, the winter market
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
