[postgis-users] connection postgis by ArcMap
Barend Köbben
kobben at itc.nl
Thu Mar 23 06:45:25 PST 2006
We use the FME interop and PostGIS 1.0.4, and indeed earlier found errors with the 'old' FME version, plus a bug in the SRID implementation of our Dutch projection system. The guys at FME were very helpful and after updating to the build FME Extension for ArcGIS Build 2182 (20051216) it now works fine for us...
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of marco vieira
> Sent: 23 March 2006 15:35
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] connection postgis by ArcMap
> Jaromir:
> See the version of your Data Interoperability (FME build in
> fact). Maybe it can connect only with older versions of
> PostGIS (0.9x).
> Regards.
> 2006/3/23, Jaromír Kamler <kamler at centrum.cz>:
> Hallo,
> I want connect to PostGIS by ArcMap:
> postgis_full_version
> POSTGIS="1.1.1" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STATS
> I have ArcGIS 9.1. and licence for data
> interoperability, when I select some layers in ArcCatalog
> from PostGIS server and insert them into ArcMap it fail:
> Application Error The instruction at 0x77fcb0c8 referenced
> memory at 0x01500050. The memory could not be "written".
> Does anyone expirience with connecting ArcMap to PostGIS server?
> Thanks for your advices.
> Jaromir Kamler
> postgis-users mailing list
> Marco Vieira
> +55 21 9499-6800
> e-mail: maovieira at gmail.com
