[postgis-users] Problem when installing on Windows XP SP2
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Mar 27 03:14:14 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Lauro Bolado
> Sent: 27 March 2006 01:29
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Problem when installing on Windows XP SP2
> Hello Mark.
(cut)
Hi Lauro,
> One thing i noticed was that i tried to include the postgres user as an
> Administrator, but remove this option cause as this role, the database
> couldn't even get started. So i took it out and include him only as part
> of the Users role with full access to the entire drive.
Yes, PostgreSQL 8.1 won't start as an administrative user. This is so in
case your server gets hacked then a remote user can't access your entire
computer.
The only other thing that could stop liblwgeom.dll from loading is that it
can't find a dependent DLL. Can you confirm that your PostgreSQL bin/
directory contains the following DLLs (and they are readable by the
PostgreSQL user):
	Libgeos_c-1.dll
	Libgeos-2.dll
	Libproj.dll
Another related reason for a failure could be that you may already have some
of the above DLLs, perhaps older versions, in your WINDOWS or WINDOWS/SYSTEM
directory from another GIS package and liblwgeom.dll is failing with a
version mismatch. Try searching for them on your computer to see if they
already exist somewhere else.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
