[postgis-users] Mapserver and Postgis
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Mar 28 05:36:35 PST 2006
Yes, I have a root account on webserver.
Best regards...
Ezequias
Obe, Regina DND\MIS escreveu:
> It could be that your webserver doesn't allow outbound connections on
> 5432 because it has a firewall in front blocking.  As Greg mentioned it
> sounds like you aren't connecting at all.
> Do you have root access to your webserver?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]
> Sent: Tuesday, March 28, 2006 8:02 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Mapserver and Postgis
> Gregory,
> Many thanks but there is notthing on the  postgresql-Tue.log :-( .
> I can start and stop the postgresql without problem. I use postmaster -D
> way.
> Another thing. How can I ping using mapserver ?
> Another thing2:I can log to postgis using ssh connection (as root and
> after as postgres user).
> Another thing3:There is no password to postgis ( linux )user. The
> postgis (database) user has yes a password (and I used on the map file)
> I hope  you could understand my enviroment.
> Ezequias
> Gregory S. Williamson escreveu:
>> Ezequias --
>> What does the postgres log say ? That's a good place to start
>> debugging this.
>> The text that you quoted has several very good suggestions; assuming
>> that the connection string seems rational to you, i.e. user, password,
>> server and database are all sane, I would suggest making sure that you
>> can can ping the postgres server from the mapserver ... if so
>> Check the postgres log and see if it is refusing the connection. if it
>> is you need to add the postgres user (not a great idea to exposte the
>> DBA account as a working account, but that's another issue) and the IP
>> address to the .hba file on the postres server. That file controls who
>> can connect and can't; it is in the root of the directory the postgres
>> database was created in.
>> If there is nothing in the log I'd suspect the TCP issue, or some
>> routing issue since postgres will write a useful message if an
>> un-authorized user tries to connect. Presumably the postgres user has
>> permissions to connect to the database and access the tables.
>> It is possible the postgres instance was not started with the proper
>> to allow TCP/IP connections; that is controlled by the script that
>> starts the postgres database. I'm not sure if the error log would show
>> anything in this case.
>> HTH, post back your results and maybe others can help more.
>> Greg Williamson
>> DBA
>> GlobeXplorer LLC
>> From:	postgis-users-bounces at postgis.refractions.net on behalf of
>> Sent:	Tue 3/28/2006 4:35 AM
>> Cc:
>> Subject:	[postgis-users] Mapserver and Postgis
>> Hi list,
>> I don't know if this is a off-topic, but as nobody from mapserver
>> could
>> solve my problem I will report to you now.
>> I am trying to connect my mapserver project to PostGIS but my browser
>> always report the folowing error:
>> msDrawMap(): Image handling error. Failed to draw layer named
> 'bairros'.
>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
>> connect string 'user=postgres password=***** dbname=db host=xxx.xxx
>> port=5432'.
>> Error reported was 'could not create socket: Permission denied '.
>> This error occured when trying to make a connection to the specified
>> postgresql server.
>> Most commonly this is caused by
>> (1) incorrect connection string
>> (2) you didnt specify a 'user=...' in your connection string
>> (3) the postmaster (postgresql server) isnt running
>> (4) you are not allowing TCP/IP connection to the postmaster
>> (5) your postmaster is not running on the correct port - if its not on
>> 5432 you must specify a 'port=...'
>> (6) the security on your system does not allow the webserver (usually
>> user 'nobody') to make socket connections to the postmaster
>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>> different machine
>> (8) you made a typo
>> Could someone help me. As simple as possible would be very glad.
>> Sincerely...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
