[postgis-users] Mapserver and Postgis
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Wed Mar 29 03:53:21 PST 2006
Obe, Regina DND\MIS escreveu:
> Is that machine your workstation or the webserver? If its not the
> webserver, then are you able to do the same test when logged in on the
> webserver?
This is my machine. I am using the -h option to connect to a webserver.
> What does your pg_hba.conf on your postgresql server look like? This
> by default is in the data directory of your postgresql server. As
> Gregory mentioned this controls what computers are allowed to connect to
> the postgresql daemon.
My pg_hba.conf
# TYPE DATABASE USER CIDR-ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all trust
# IPv4 local connections:
host all all 10.0.0.0 255.0.0.0 password
host all all 172.0.0.0 255.0.0.0 password
host all all 192.168.0.0 255.0.0.0 password
host all all 127.0.0.1/32 trust
host all all 200.249.133.135 255.255.255.255
password
# IPv6 local connections:
host all all ::1/128 trust
host all all 192.168.0.0 255.255.0 0 password
That's it.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]
> Sent: Tuesday, March 28, 2006 11:50 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Mapserver and Postgis
> Obe,
> Fortunately I have psql here in my machine and I tryed to connect using
> it.
> The connection was ok with your parameters psql -U postgres
> machine.domainmachine db
> Have you any suggestion ?
> Ezequias
>> Ezequias,
>> Then I guess one thing to try would be connect into your webserver via ssh or some other means and then do a ping on your postgresql server.
>> That may not work depending on whether pinging is blocked or not.
>> If you had a psql client on the webserver or can easily put one on,
>> then you can do more indepth analysis. With something like below
>> psql -h myserver.mydomain.com mydb
>> Also you said you logged in using ssh from your local computer to the
>> postgresql server. Did you try connecting to the postgresql server
>> via the psql client from your local pc. Just because you can ssh into
>> the postgresql server doesn't necessarily mean postgres daemon is
>> listening on a TCP/IP port.
>> Sent: Tuesday, March 28, 2006 8:37 AM
>> Yes, I have a root account on webserver.
>> Best regards...
>> Ezequias
>>> It could be that your webserver doesn't allow outbound connections on
>>> 5432 because it has a firewall in front blocking. As Greg mentioned
>>> it sounds like you aren't connecting at all.
>>> Do you have root access to your webserver?
>>> Sent: Tuesday, March 28, 2006 8:02 AM
>>> Gregory,
>>> Many thanks but there is notthing on the postgresql-Tue.log :-( .
>>> I can start and stop the postgresql without problem. I use postmaster
>>> -D
>>> way.
>>> Another thing. How can I ping using mapserver ?
>>> Another thing2:I can log to postgis using ssh connection (as root and
>>> after as postgres user). Another thing3:There is no password to
>>> postgis ( linux )user. The postgis (database) user has yes a password
>>> (and I used on the map
>> file)
>>> I hope you could understand my enviroment.
>>> Ezequias
>>> Gregory S. Williamson escreveu:
>>>> Ezequias --
>>>> What does the postgres log say ? That's a good place to start
>>>> debugging this.
>>>> The text that you quoted has several very good suggestions; assuming
>>>> that the connection string seems rational to you, i.e. user,
>> password,
>>>> server and database are all sane, I would suggest making sure that
>>>> you
>>>> can can ping the postgres server from the mapserver ... if so
>>>> Check the postgres log and see if it is refusing the connection. if
>>>> it
>>>> is you need to add the postgres user (not a great idea to exposte
>>>> the DBA account as a working account, but that's another issue) and
>>>> the
>> IP
>>>> address to the .hba file on the postres server. That file controls
>>>> who
>>>> can connect and can't; it is in the root of the directory the
>>>> postgres
>>>> database was created in.
>>>> If there is nothing in the log I'd suspect the TCP issue, or some
>>>> routing issue since postgres will write a useful message if an
>>>> un-authorized user tries to connect. Presumably the postgres user
>>>> has
>>>> permissions to connect to the database and access the tables.
>>>> It is possible the postgres instance was not started with the proper
>>>> to allow TCP/IP connections; that is controlled by the script that
>>>> starts the postgres database. I'm not sure if the error log would
>> show
>>>> anything in this case.
>>>> HTH, post back your results and maybe others can help more.
>>>> Greg Williamson
>>>> DBA
>>>> GlobeXplorer LLC
>>>> From: postgis-users-bounces at postgis.refractions.net on behalf
>> of
>>>> Sent: Tue 3/28/2006 4:35 AM
>>>> Cc:
>>>> Subject: [postgis-users] Mapserver and Postgis
>>>> Hi list,
>>>> I don't know if this is a off-topic, but as nobody from mapserver
>>>> could solve my problem I will report to you now.
>>>> I am trying to connect my mapserver project to PostGIS but my
>>>> browser
>>>> always report the folowing error:
>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>> 'bairros'.
>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>> with connect string 'user=postgres password=***** dbname=db
>>>> host=xxx.xxx port=5432'. Error reported was 'could not create
>>>> socket: Permission denied '. This error occured when trying to make
>>>> a connection to the specified postgresql server.
>>>> Most commonly this is caused by
>>>> (1) incorrect connection string
>>>> (2) you didnt specify a 'user=...' in your connection string
>>>> (3) the postmaster (postgresql server) isnt running
>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>> (5) your postmaster is not running on the correct port - if its not
>> on
>>>> 5432 you must specify a 'port=...'
>>>> (6) the security on your system does not allow the webserver
>>>> (usually user 'nobody') to make socket connections to the postmaster
>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>> different machine
>>>> (8) you made a typo
>>>> Could someone help me. As simple as possible would be very glad.
>>>> Sincerely...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
