[postgis-users] mezoGIS problems
Stephen Davies
sdc at sdc.com.au
Wed Mar 29 15:23:04 PST 2006
G'day.
I have installed MezoGIS on my Linux system (home made; no distro) with
the latest version I could find of all dependencies.
If I run it as an ordinary user, I get:
bash-3.1$ mezogis.py
File "/usr/local/bin/mezogis.py", line 14, in ?
from mezoGISlib import PGButler
File "/usr/local/lib/python2.4/site-packages/mezoGISlib/__init__.py",
line 18, in ?
from _guicore import PGButler
File "/usr/local/lib/python2.4/site-packages/mezoGISlib/_guicore.py",
line 22, in ?
import gtk
File "/usr/local/lib/python2.4/site-packages/gtk-2.0/gtk/__init__.py",
line 38, in ?
from _gtk import *
ImportError: /usr/local/lib/libpangoft2-1.0.so.0: undefined symbol:
g_intern_static_string
If I run it as root, it starts up OK but when I try to connect to a
database, I get:
bash-3.1# mezogis.py
Another module named "tesselate" is already in use.
load "/usr/local/share/mezogis/plugins/tesselate.py"
Could not load plugins:
[Errno 2] No such file or directory: '/.mezogis/plugins'
FATAL: database "root" does not exist
[Errno 2] No such file or directory: '/.mezogis/history'
Exception in thread Thread-1:
File "/usr/local/lib/python2.4/threading.py", line 442, in __bootstrap
self.run()
File "/usr/local/lib/python2.4/site-packages/mezoGISlib/_dbtools.py",
line 86, in run
row = c.fetchone()
File
"/usr/local/lib/python2.4/site-packages/GeoTypes/_PsycopgInit.py", line
92, in __call__
if ord(s[0]) < 32:
TypeError: unsubscriptable object
The first error looks like a permissions thing but I can't see where.
The second error says nothing to me. Any ideas?
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
