[postgis-users] mezoGIS problems
marcos boullón magán
marcosboullon at gmail.com
Thu Mar 30 01:03:27 PST 2006
I agree with you. First error seems permissions related.
The second error is a complain about the database. mezoGIS needs a
directory $HOME/.mezogis with some data or it'll try default values,
and the default values includes a conection to localhost.
Try this (with the user you launch mezoGIS):
$ mkdir ~/.mezogis
$ mkdir ~/.mezogis/plugins
$ touch ~/.mezogis/history
Now you start mezoGIS and change the database connection parameters;
if still fails, try also the following with your parameters.
$ cat > ~/.mezogis/mezogisrc
[connection]
port = 5432
host = your_postgresql_server
user = postgres
dbname = your_geodatabase_name
pw =
^D
Good luck,
M.
2006/3/30, Stephen Davies <sdc at sdc.com.au>:
> G'day.
> I have installed MezoGIS on my Linux system (home made; no distro) with
> the latest version I could find of all dependencies.
> If I run it as an ordinary user, I get:
> bash-3.1$ mezogis.py
> Traceback (most recent call last):
> File "/usr/local/bin/mezogis.py", line 14, in ?
> from mezoGISlib import PGButler
> File "/usr/local/lib/python2.4/site-packages/mezoGISlib/__init__.py",
> line 18, in ?
> from _guicore import PGButler
> File "/usr/local/lib/python2.4/site-packages/mezoGISlib/_guicore.py",
> line 22, in ?
> import gtk
> File "/usr/local/lib/python2.4/site-packages/gtk-2.0/gtk/__init__.py",
> line 38, in ?
> from _gtk import *
> ImportError: /usr/local/lib/libpangoft2-1.0.so.0: undefined symbol:
> g_intern_static_string
> If I run it as root, it starts up OK but when I try to connect to a
> database, I get:
> bash-3.1# mezogis.py
> Another module named "tesselate" is already in use.
> load "/usr/local/share/mezogis/plugins/tesselate.py"
> Could not load plugins:
> [Errno 2] No such file or directory: '/.mezogis/plugins'
> FATAL: database "root" does not exist
> [Errno 2] No such file or directory: '/.mezogis/history'
> Exception in thread Thread-1:
> File "/usr/local/lib/python2.4/threading.py", line 442, in __bootstrap
> self.run()
> File "/usr/local/lib/python2.4/site-packages/mezoGISlib/_dbtools.py",
> line 86, in run
> row = c.fetchone()
> File
> "/usr/local/lib/python2.4/site-packages/GeoTypes/_PsycopgInit.py", line
> 92, in __call__
> if ord(s[0]) < 32:
> TypeError: unsubscriptable object
> The first error looks like a permissions thing but I can't see where.
> The second error says nothing to me. Any ideas?
> This email is for the person(s) identified above, and is confidential to
> the sender and the person(s). No one else is authorised to use or
> disseminate this email or its contents.
> Stephen Davies Consulting Voice: 08-8177 1595
> Adelaide, South Australia. Fax: 08-8177 0133
> Computing & Network solutions. Mobile:0403 0405 83
> postgis-users mailing list
-- marcos boullón magán
