[postgis-users] adding additional points to multipoint
Markus Schaber
schabi at logix-tt.com
Fri Mar 31 03:53:01 PST 2006
Hi, Christo,
Christo Du Preez wrote:
> Thank you,
> When trying
> update meclabel
> set the_geom = geomunion(the_geom, GeomFromText('POINT(23 4)', -1))
> I get:: ERROR: new row for relation "meclabel" violates check
> constraint "enforce_geotype_the_geom"
Hmm, I did not cast it in my tests, but I guess that, depending on your
PostGIS version, Geomunion might return a GeometryCollection instead of
an MultiPoint.
Can you see what PostGIS version you have?
Can you execute
select asText(geomunion('MULTIPOINT(1 1,3 3)',
geomFromText('POINT(2 2)',-1)));
and tell us its output?
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTIPOINT'::text OR the_geom IS NULL),
This is the "guilty" constraint that blocks all non-multipoint
geometries from being inserted into the table.
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in EU! www.ffii.org www.nosoftwarepatents.org
