[postgis-users] adding additional points to multipoint
Christo Du Preez
christo at mecola.com
Fri Mar 31 05:31:59 PST 2006
The result is: "MULTIPOINT(1 1,2 2,3 3)"
The version is: "POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel.
4.4.9, 29 Oct 2004" USE_STATS"
Markus Schaber wrote:
> Hi, Christo,
> Christo Du Preez wrote:
>> Thank you,
>> When trying
>> update meclabel
>> set the_geom = geomunion(the_geom, GeomFromText('POINT(23 4)', -1))
>> I get:: ERROR: new row for relation "meclabel" violates check
>> constraint "enforce_geotype_the_geom"
> Hmm, I did not cast it in my tests, but I guess that, depending on your
> PostGIS version, Geomunion might return a GeometryCollection instead of
> an MultiPoint.
> Can you see what PostGIS version you have?
> Can you execute
> select asText(geomunion('MULTIPOINT(1 1,3 3)',
> geomFromText('POINT(2 2)',-1)));
> and tell us its output?
>> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
>> 'MULTIPOINT'::text OR the_geom IS NULL),
> This is the "guilty" constraint that blocks all non-multipoint
> geometries from being inserted into the table.
> Markus
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]83 326 8087
