[postgis-users] quickie question
Stephen Marshall smarshall at wsi.com
Tue May 2 09:06:59 PDT 2006
Meghan,
You are trying to use psql backslash commands within a plpgsql
server-side function.  The backslash commands are specific just to the
psql application, which is just one specific PostgreSQL client
application.  The plpglsql code runs within the PostgreSQL backend (i.e.
on the server-side), and hence is independent of which client program or
interface you are using.
Typically, to output the results of a server-side function to a file,
write your function to return a set of records, i.e. SETOF <table_name
or aggregate data type>.   You can define the record type either with
the create table or create type commands.
Then, execute your function using psql (or another client application)
and redirect the output of the client application into a file.
e.g. This command will output your query results as comma-separated
variables and redirect it into a file.
psql --no-align -F, --pset footer -c "your query" yourdb  >  yourfile
Yours,
Steve Marshall
