[postgis-users] generating ocean
Guido Lemoine
guido.lemoine at jrc.it
Tue May 2 23:45:24 PDT 2006
For a good quality global coastline (shoreline) check out the gshhs
(full res version)
at http://www.soest.hawaii.edu/wessel/gshhs/gshhs.html
We have loaded this into postgis and use it for land masking of SAR
imagery, so
that we can detect vessel positions (ocean masking is the reverse). The
global consistency
and detail of gshhs is remarkable (better than VMAP0). For ocean
masking, we use the
approach just sent by Brent Wood (i.e. differencing with a bounding box
that is, in our
case, the SAR image frame).
Guido Lemoine
Brent Wood wrote:
>--- Christo Du Preez <christo at mecola.com> wrote:
>>Hi All,
>>What is the best way to generate an ocean geometry if I have a country
>>boundary? Or is this downloadable somewhere as free gis?
>There are a few free global datasets, but you will probably find the coastlines
>vary from yours.
>You might try to select the difference between your coastline & a bounding box
>encompassing the coastline area, the postgis difference funtion should do this.
>Brent Wood
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
