[postgis-users] Rhumb lines
David Bitner
osgis.lists at gmail.com
Fri May 5 11:11:36 PDT 2006
Am I completely off base, or would reprojecting the start and end
point to a mercator (not a transverse mercator) projection, connect
the points, fill in the gap with additional points (would the
segmentize() function do this? it seems to be just for polygons) and
reproject back to original projection.
On 5/5/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Paul Scott wrote:
> > Is there a quick and easy way that anyone has implemented calculating
> > Rhumb lines from geometries in PostGIS? If not, I would like to try and
> > get something working in PHP and then as a PostGIS function.
> > Any hints/clues?
> http://en.wikipedia.org/wiki/Rhumb_lines
> postgis-users mailing list
