[postgis-users] Rhumb lines
Paul Scott pscott at uwc.ac.za
Fri May 5 11:49:22 PDT 2006
On Fri, 2006-05-05 at 13:25 -0500, David Bitner wrote:
> I forgot to put in a distance for the segmentize, here it is with 100m:
> select transform(segmentize(transform(makeline(a,b),9804)),100),4326)
Thanks very much. I am going to do some experimentation and then try and
code up a php class that does the PostGIS solution as well as a pure PHP
one.
Thanks again!
--Paul
