[postgis-users] Rhumb lines
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Fri May 5 12:01:26 PDT 2006
Hi all....
View my build proyects, in CHILE... with MapServer and Postgis... and more
functions... is very goods.
LINK....
http://datum.siigsa.cl
the very important is ... the data catografics, is in repository
"geo-datawarehouse".... postgres 7.4.8.... size 4,6 GB now. AND model
relational oriented a objects data,
after suscribe in the site and upload your shape, and contents.
bye.
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, May 05, 2006 2:49 PM
Subject: Re: [postgis-users] Rhumb lines
> On Fri, 2006-05-05 at 13:25 -0500, David Bitner wrote:
> > I forgot to put in a distance for the segmentize, here it is with 100m:
> > select transform(segmentize(transform(makeline(a,b),9804)),100),4326)
> Thanks very much. I am going to do some experimentation and then try and
> code up a php class that does the PostGIS solution as well as a pure PHP
> one.
> Thanks again!
> --Paul
> postgis-users mailing list
