[postgis-users] Re: problem with BOX3D query
Randy George
rkgeorge at cadmaps.com
Mon May 8 11:57:12 PDT 2006
Hi Marc,
I believe I'm using one of your latest builds for PostgreSQL 8.1:
SELECT postgis_full_version()
"POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS DBPROC="0.3.0" RELPROC="1.1.1" (needs proc upgrade)"
I've tried the query with and without the space before comma and after
comma, but receive the same error.
I've also tried adding zmin zmax:
SELECT the_geom FROM streets
WHERE the_geom && SetSRID(BOX3D(-111.80 33.30 0.0, -111.75 33.35
0.0)::box3d,4269);
ERROR: syntax error at or near "33.30" at character 72
Thanks
Randy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Monday, May 08, 2006 5:25 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Re: problem with BOX3D query
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Randy
George
> Sent: 06 May 2006 18:21
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Re: problem with BOX3D query
> Hi,
> Im trying to find my error in a BOX3D query
> "PostgreSQL 8.1.2 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
(mingw-
> special)" In Windows 2003 environment
> WHERE the_geom && SetSRID(BOX3D(-111.80 33.30 , -111.75
33.35)::box3d,4269);
> Gives ERROR: syntax error at or near "33.30" at character 72
> But identical BOX3D here
> select AsEWKT(SetSRID('BOX3D(-111.80 33.30 , -111.75 33.35)'::box3d,
4269));
> Works fine?
> "SRID=4269;POLYGON((-111.8 33.3,-111.8 33.35,-111.75 33.35,-111.75
33.3,-111.8 33.3))"
> Substituting POLYGON
> WHERE the_geom && GeomFromText('POLYGON((-111.8 33.3,-111.8 33.35,-111.75
33.35,-111.75
> 33.3,-111.8 33.3))',4269)
> Works as expected
> As does he simpler LINESTRING bounding box
> WHERE the_geom && GeomFromText('LINESTRING(-111.80 33.30, -111.75
33.35)',4269)
> However Im curious why the BOX3D isnt working?
> Thanks
> Rkgeorge
Hi Randy,
Using PostGIS 1.0.3, I see the following behaviour:
postgis=# SELECT geom FROM osgb_text
postgis-# WHERE geom && SetSRID('BOX3D(-111.80 33.30 , -111.75
33.35)'::box3d,4269);
ERROR: BOX3D parser - couldnt parse. It should look like: BOX3D(xmin ymin
zmin,xmax ymax zmax) or BOX3D(xmin ymin,xmax ymax)
postgis=# select postgis_full_version();
POSTGIS="1.0.3" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
(1 row)
Removing the space before the comma in the BOX3D allows the statement to
execute without problems here. Which version of PostGIS are you using?
(SELECT postgis_full_version()). I wonder if it could be something to do
with the Geometry <-> BOX3D cast used to query the indices.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
