[postgis-users] Re: problem with BOX3D query
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Mon May 8 12:07:01 PDT 2006
hi,
change field the_geom position....
SELECT the_geom FROM streets
WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 0.0, -111.75
33.350.0)'::box3d,4269);
example
$sqldata="the_geom from (SELECT * FROM ".$table." WHERE
SetSRID('BOX3D(".$ext[0]." ".$ext[1].",".$ext[2]." ".$ext[3].")'::box3d,-1)
&& the_geom ) as foo using unique gid using SRID=-1";
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Sent: Monday, May 08, 2006 2:57 PM
Subject: RE: [postgis-users] Re: problem with BOX3D query
> Hi Marc,
> I believe I'm using one of your latest builds for PostgreSQL 8.1:
> SELECT postgis_full_version()
> "POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS DBPROC="0.3.0" RELPROC="1.1.1" (needs proc upgrade)"
> I've tried the query with and without the space before comma and after
> comma, but receive the same error.
> I've also tried adding zmin zmax:
> WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 0.0, -111.75 33.35
> 0.0)'::box3d,4269);
> ERROR: syntax error at or near "33.30" at character 72
> Thanks
> Randy
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
> Cave-Ayland
> Sent: Monday, May 08, 2006 5:25 AM
> To: 'PostGIS Users Discussion'
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Randy
> George
> > Sent: 06 May 2006 18:21
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Re: problem with BOX3D query
> > Hi,
> > I'm trying to find my error in a BOX3D query
> > "PostgreSQL 8.1.2 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
3.4.2
> (mingw-
> > special)" In Windows 2003 environment
> > WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 , -111.75
> 33.35)'::box3d,4269);
> > Gives ERROR: syntax error at or near "33.30" at character 72
> > But identical BOX3D here
> > select AsEWKT(SetSRID('BOX3D(-111.80 33.30 , -111.75 33.35)'::box3d,
> 4269));
> > Works fine?
> > "SRID=4269;POLYGON((-111.8 33.3,-111.8 33.35,-111.75 33.35,-111.75
> 33.3,-111.8 33.3))"
> > Substituting POLYGON
> > WHERE the_geom && GeomFromText('POLYGON((-111.8 33.3,-111.8
33.35,-111.75
> 33.35,-111.75
> > 33.3,-111.8 33.3))',4269)
> > Works as expected
> > As does he simpler LINESTRING bounding box
> > WHERE the_geom && GeomFromText('LINESTRING(-111.80 33.30, -111.75
> 33.35)',4269)
> > However I'm curious why the BOX3D isn't working?
> > Thanks
> > Rkgeorge
> Hi Randy,
> Using PostGIS 1.0.3, I see the following behaviour:
> postgis=# SELECT geom FROM osgb_text
> postgis-# WHERE geom && SetSRID('BOX3D(-111.80 33.30 , -111.75
> ERROR: BOX3D parser - couldnt parse. It should look like: BOX3D(xmin
ymin
> zmin,xmax ymax zmax) or BOX3D(xmin ymin,xmax ymax)
> postgis=# select postgis_full_version();
> POSTGIS="1.0.3" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"
> (1 row)
> Removing the space before the comma in the BOX3D allows the statement to
> execute without problems here. Which version of PostGIS are you using?
> (SELECT postgis_full_version()). I wonder if it could be something to do
> with the Geometry <-> BOX3D cast used to query the indices.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it
or
> use it for any purpose nor disclose or distribute its contents to any
other
> person.
> postgis-users mailing list
