[postgis-users] Re: problem with BOX3D query
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Mon May 8 14:22:14 PDT 2006
welcome,
congratulations Randy....
one it more... function geometryfromtext is out, replace for SetSRID only
call BOX3D function...
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Sent: Monday, May 08, 2006 5:04 PM
Subject: RE: [postgis-users] Re: problem with BOX3D query
> Hi Patricio,
> Thank you very much! Mystery solved!
> I had copy/pasted Box3D from the PostGIS pdf manual and failed to notice
> that the apostrophe changes:
> pdf ' = hex 92 instead of hex 27 '
> once I change to hex 27 apostrophe everything works as expected.
> >From pdf manual:
> SELECT
> AsText(GEOM) AS GEOM
> FROM ROADS_GEOM
> WHERE
> GEOM && GeomFromText('BOX3D(191232 243117,191232 243119)'::box3d,-1);
> Note the apostrophe!
> SELECT the_geom FROM streets
> WHERE the_geom && SetSRID('BOX3D(-111.80 33.30,-111.75
33.35)'::box3d,4269);
> will not work
> but
> will work as expected.
> Interestingly -
> WHERE the_geom && GeomFromText('BOX3D(-111.80 33.30,-111.75
> Produces response:
> ERROR: function geomfromtext(box3d, integer) does not exist
> HINT: No function matches the given name and argument types. You may need
> to add explicit type casts.
> So manual may need to be updated?
> Thanks
> Randy
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Patricio
> Cifuentes Ithal
> Sent: Monday, May 08, 2006 2:18 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Re: problem with BOX3D query
> Hi Randy,
> sorry I'am very explicyt... so now send example much.
> example
> SELECT * FROM table WHERE SetSRID('BOX3D(111.80 33.30,-111.75
> 33.350)'::box3d,4269) && the_geom
> Informática
> SIIGSA
> (56-2) 204 60 22
> From: "Randy George" <rkgeorge at cadmaps.com>
> Sent: Monday, May 08, 2006 3:52 PM
> > Hi Patricio,
> > Perhaps I'm not understanding your suggestion correctly but
> > reversing fields:
> > WHERE SetSRID('BOX3D(-111.80 33.30,-111.75 33.35)'::box3d,4269) &&
> the_geom;
> > Produces the same response:
> > ERROR: syntax error at or near "33.30" at character 60
> > Thanks
> > Randy
> Patricio
> > Cifuentes Ithal
> > Sent: Monday, May 08, 2006 1:07 PM
> > hi,
> > change field the_geom position....
> > WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 0.0, -111.75
> > 33.350.0)'::box3d,4269);
> > example
> > $sqldata="the_geom from (SELECT * FROM ".$table." WHERE
> > SetSRID('BOX3D(".$ext[0]." ".$ext[1].",".$ext[2]."
> ".$ext[3].")'::box3d,-1)
> > && the_geom ) as foo using unique gid using SRID=-1";
> > Informática
> > SIIGSA
> > (56-2) 204 60 22
> > Sent: Monday, May 08, 2006 2:57 PM
> > > Hi Marc,
> > > I believe I'm using one of your latest builds for PostgreSQL 8.1:
> > > SELECT postgis_full_version()
> > > "POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct
2004"
> > > USE_STATS DBPROC="0.3.0" RELPROC="1.1.1" (needs proc upgrade)"
> > > I've tried the query with and without the space before comma and after
> > > comma, but receive the same error.
> > > I've also tried adding zmin zmax:
> > > WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 0.0, -111.75 33.35
> > > 0.0)'::box3d,4269);
> > > ERROR: syntax error at or near "33.30" at character 72
> > > Thanks
> > > Randy
Mark
> > > Cave-Ayland
> > > Sent: Monday, May 08, 2006 5:25 AM
> > > To: 'PostGIS Users Discussion'
> Randy
> > > George
> > > > Sent: 06 May 2006 18:21
> > > > To: postgis-users at postgis.refractions.net
> > > > Subject: [postgis-users] Re: problem with BOX3D query
> > > > Hi,
> > > > I'm trying to find my error in a BOX3D query
> > > > "PostgreSQL 8.1.2 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
> > 3.4.2
> > > (mingw-
> > > > special)" In Windows 2003 environment
> > > > WHERE the_geom && SetSRID('BOX3D(-111.80 33.30 , -111.75
> > > > Gives ERROR: syntax error at or near "33.30" at character 72
> > > > But identical BOX3D here
> > > > select AsEWKT(SetSRID('BOX3D(-111.80 33.30 , -111.75 33.35)'::box3d,
> > > 4269));
> > > > Works fine?
> > > > "SRID=4269;POLYGON((-111.8 33.3,-111.8 33.35,-111.75 33.35,-111.75
> > > 33.3,-111.8 33.3))"
> > > > Substituting POLYGON
> > > > WHERE the_geom && GeomFromText('POLYGON((-111.8 33.3,-111.8
> > 33.35,-111.75
> > > 33.35,-111.75
> > > > 33.3,-111.8 33.3))',4269)
> > > > Works as expected
> > > > As does he simpler LINESTRING bounding box
> > > > WHERE the_geom && GeomFromText('LINESTRING(-111.80 33.30, -111.75
> > > 33.35)',4269)
> > > > However I'm curious why the BOX3D isn't working?
> > > > Thanks
> > > > Rkgeorge
> > > Hi Randy,
> > > Using PostGIS 1.0.3, I see the following behaviour:
> > > postgis=# SELECT geom FROM osgb_text
> > > postgis-# WHERE geom && SetSRID('BOX3D(-111.80 33.30 , -111.75
> > > ERROR: BOX3D parser - couldnt parse. It should look like: BOX3D(xmin
> > ymin
> > > zmin,xmax ymax zmax) or BOX3D(xmin ymin,xmax ymax)
> > > postgis=# select postgis_full_version();
> > > POSTGIS="1.0.3" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> > > DBPROC="0.3.0" RELPROC="0.3.0"
> > > (1 row)
> > > Removing the space before the comma in the BOX3D allows the statement
to
> > > execute without problems here. Which version of PostGIS are you using?
> > > (SELECT postgis_full_version()). I wonder if it could be something to
do
> > > with the Geometry <-> BOX3D cast used to query the indices.
> > > Kind regards,
> > > Mark.
> > > WebBased Ltd
> > > 17 Research Way
> > > Plymouth
> > > PL6 8BT
> > > T: +44 (0)1752 797131
> > > F: +44 (0)1752 791023
> > > http://www.webbased.co.uk
> > > http://www.infomapper.com
> > > http://www.swtc.co.uk
> > > This email and any attachments are confidential to the intended
> recipient
> > > and may also be privileged. If you are not the intended recipient
please
> > > delete it from your system and notify the sender. You should not copy
it
> > or
> > > use it for any purpose nor disclose or distribute its contents to any
> > other
> > > person.
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
