[postgis-users] postgis.pdf
strk at refractions.net
Thu May 11 02:42:39 PDT 2006
On Wed, May 10, 2006 at 05:19:29PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net wrote:
> > That's because you don't meet the requirements.
> Weird, because I used to generate the pdf file - it seems that part of
> my tex installation got dropped by some dist-upgrade
> > I've added a README file under doc/ listing them.
> Ah, fine, thanks.
> That reminds me that I wanted update the jdbc part of the manual, and
> find some way to auto-include the Java Documentation...
> > PS: note, rule is "$(PDFXMLTEX) postgis.fo", so
> > you only miss the pdfxmltex part.
> Argh - Shell style command expansion can be confusing. I always wish to
> have a "$(PDFXMLTEX) - commmand not found" in this case...
> Btw, I'd propose to include postgis.fo and postgis.pdf in .cvsignore.
Committed.
> Now, I get the following:
> [snip]
> [4] [5] [6]
> ! LaTeX Error: Something's wrong--perhaps a missing \item.
Yep, same error here.
I tried with older postgis versions and I get the same,
so I presume a dist-upgrade on my side too..
We need to test on other systems to tell.
--strk;
