[postgis-users] Resolved - Error from lwpostgis.sql re: GEOS
Daniel Ricard
ricardd at mathstat.dal.ca
Thu May 11 15:43:29 PDT 2006
Hello,
The error that I was getting when loading lwpostgis.sql stemmed from GEOS and
PROJ4 being in non-conventional locations.
The quick fix was to symlink the GEOS and PROJ4 libraries from the postgreSQL
lib directory (/usr/local/postgresql/lib/ in the following) to their
non-conventional locations:
> cd /usr/local/postgresql/lib/
> sudo ln -s /usr/local/lib/libgeos* .
> sudo ln -s /usr/local/proj4/lib/libproj.* .
Thanks for all your help.
Gracias a todos.
Obrigado a todos.
Dan
Le 2 Mai 2006 16:24 :
> Hello,
> I have downloaded and built from source the latest versions of postgreSQL,
> GEOS, proj4 and postGIS.
> I thought that the installation was all good but I'm now getting an error
> when trying to "psql -U postgres -d myDB -f lwpostgis.sql":
> psql:/usr/local/postgresql/share/contrib/lwpostgis.sql:39: ERROR: could
> not load library "/usr/local/postgresql/lib/liblwgeom.so.1.1":
> libgeos_c.so.1: cannot open shared object file: No such file or directory
> The GEOS library is installed in /usr/local and I have correctly set the
> GEOS_DIR in Makefile.config for postGIS.
> Here is what configure tells me:
> SUMMARY
> HOST_OS: linux-gnu
> PGSQL: /usr/local/postgresql/bin/pg_config
> GEOS: /usr/local/bin/geos-config (with C-API)
> PROJ: dir=/usr/local/proj4
> I also ran "ldconfig" after installing GEOS.
> Any ideas about what I am doing wrong here?
> Cheers,
> Dan
