[postgis-users] Performance of seperate spatial data
Ries van Twisk
postgis at rvt.dds.nl
Fri May 12 04:37:35 PDT 2006
Eric,
you can speed up you queries if you use a different tablespace for your
indexes and your table.
Ofcourse you need to make sure that each tablespace sits on a different
phisical harddisk
(I have seen people that put it on a different partition thought that
was the way...).
Unless the number of attributes is uge, I don't think you will gain much
by seperating spatial data from attribute data.
Ries
> Hello list,
> would there be any performance gain if I were to put all the
> spatial/geometry data in one table and the other attributes [numbers,
> text ..] in a seperate table? If so, what would be the correct way to
> link the two tables? A correlating index on both tables?
> All my queries will actually need to access both the attributes table
> and the spatial table if I were to split them up.
> Is there a good test to determine the performace bewtween having 2
> tables and just 1 table I can run to check it out?
> Regards
> Eric Lam
> postgis-users mailing list
Ries van Twisk
Freelance Typo3 Developer
email: ries at vantwisk.nl
web: http://www.rvantwisk.nl/
skype: callto://r.vantwisk
