[postgis-users] postgis help!!
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue May 16 03:55:46 PDT 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Brent Wood
> Sent: 16 May 2006 11:38
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] postgis help!!
(cut)
> Please tell me this is a bug, or I need to do something to fix the values
> returned by envelope (reset bbox for the geometry data or something?)
> ...not the new way PostGIS is supposed to behave.
> Thanks,
> Brent Wood
Hi Brent,
Could you post to the list a self-contained SQL test case to recreate your
problem? Also you say that you are using the latest versions - can you
confirm those are both PostgreSQL 8.1 and PostGIS 1.1.2 using SELECT
version() and SELECT postgis_full_version()?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
