[postgis-users] Re: srid / area
Patrick
pvanlaake at users.sourceforge.net
Tue May 16 10:40:00 PDT 2006
Hi Christo,
Maybe a silly question, but are you sure that your data are in decimal
degree and not in kilometer? That would exactly explain the order of
magnitude difference you indicated.
Regards,
Patrick
"Christo Du Preez" <christo at mecola.com> wrote in message
news:4469996A.7080009 at mecola.com...
> select area(the_geom) AS ar
> from cdsmriverareaview
> order by ar
> 6.70955000170448e-08
> the expected result is roughly 670 sq meters.
