[postgis-users] Re: srid / area
Christo Du Preez
christo at mecola.com
Wed May 17 05:04:22 PDT 2006
Hi Patrick,
Yes, I'm quite sure my data is in decimal degrees.
I ran [select UpdateGeometrySRID('public', 'cdsmriverarea', 'the_geom',
4148);] on my data. I did notice if you look below that there is no
units specified at the end. So I tried using transform with srid 2046,
which does specify units=m. And I'm still getting the same result.
4148;"EPSG";4148;"GEOGCS["Hartebeesthoek94",DATUM["Hartebeesthoek94",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6148"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY
(..)";"+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs "
2046;"EPSG";2046;"PROJCS["Hartebeesthoek94 /
Lo15",GEOGCS["Hartebeesthoek94",DATUM["Hartebeesthoek94",SPHEROID["WGS
(..)";"+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs "
Patrick wrote:
> Hi Christo,
> Maybe a silly question, but are you sure that your data are in decimal
> degree and not in kilometer? That would exactly explain the order of
> magnitude difference you indicated.
> Regards,
> Patrick
> "Christo Du Preez" <christo at mecola.com> wrote in message
> news:4469996A.7080009 at mecola.com...
>> select area(the_geom) AS ar
>> from cdsmriverareaview
>> order by ar
>> 6.70955000170448e-08
>> the expected result is roughly 670 sq meters.
> postgis-users mailing list
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]83 326 8087
