[postgis-users] Re: srid / area
Michael Fuhr
mike at fuhr.org
Wed May 17 08:25:41 PDT 2006
On Wed, May 17, 2006 at 02:04:22PM +0200, Christo Du Preez wrote:
> Yes, I'm quite sure my data is in decimal degrees.
> I ran [select UpdateGeometrySRID('public', 'cdsmriverarea', 'the_geom',
> 4148);] on my data. I did notice if you look below that there is no
> units specified at the end. So I tried using transform with srid 2046,
> which does specify units=m. And I'm still getting the same result.
SRID 2046 has proj=longlat so coordinates in that system are
apparently degrees. I don't know if that's correct but you can see
that transforming to that SRID yields degrees:
SELECT AsEWKT(Transform(GeomFromEWKT('SRID=4148;POINT(18 -33)'), 2046));
asewkt
SRID=2046;POINT(18 -33)
(1 row)
That would explain why areas still aren't in the desired units
(square meters).
Does transforming to an appropriate UTM zone give results closer
to what you're expecting? If SRID=4148;POINT(18 -33) is a
representative location then try SRID 32733 or 32734 (WGS 84 / UTM
zone 33S or 34S). Offhand I don't know if there's a more appropriate
area-preserving SRID.
Michael Fuhr
