[postgis-users] spatial_ref_sys
    trevorw
    trevorw at fanweb.ca
    Tue May 16 14:15:52 PDT 2006
I'm working in Alberta which uses a modified Transverse Mercator
projection (called 10TM) for provincial scale data.
AFAIK there is no entry in spatial_ref_sys to describe this projection.
Is there some protocol by which an entry might be added to future
versions of PostGIS and is there a recommended procedure for numbering
my own entry to avoid conflicts with future versions?
If I add my own following the format provided, I an import my data with
the -s flag and it displays nicely in QGIS, which I assume indicates
that it is functional and coordinate conversion, and other functions
will operate properly. Right?
Thanks in advance.
T
Trevor Wiens
