[postgis-users] Problem with shp2pgsql - charachter encoding
Steven De Vriendt gisaalter at gmail.com
Fri May 19 05:16:09 PDT 2006
Mark,
Yes, I'm using that version.
The shp2pgsql is running fine, the problem comes when importing the sql-file
in the PostGIS database with the psql command. psql returns a message:
Invalid UTF-8 byte sequence detected....so I assumed that something went
wrong during the shp2pgsql excution. I've now converted the resulting
sql-file in a UTF-8 encoding using the save as option in...notepad. Running
the pgsql commando then went fine.
When displaying my data in Udig I see that some attribute fields aren''t
display correct. Geometry is fine. f.i. 9880 in an attribute field is
displayed as 9880.0000000 though I don't know what has caused that.
Can you tell me something more about the W-switch and how to use it ?
On 5/19/06, Mark Cave-Ayland <m.cave-ayland at webbased.co.uk> wrote:
> ________________________________________
> > From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Steven
> De Vriendt
> > Sent: 18 May 2006 16:37
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Problem with shp2pgsql - charachter encoding
> > (cut)
> > Can someone help me with a few steps ?
> > 1) where's the location of the makefile.config - file ? I'm using
> Postgres
> 8.1.3 with
> > postgis on windows xp and can't find it...
> > 2) I suppose libiconv is an app to convert between ansi and utf ?
> > 3) I suppose I have to use the shp2pgsql command with the W-flag ? but
> how
> do I specify > the -W flag ?
> > Thanks for your help !
> Hi Steven,
> Are you using the version of PostGIS which comes with the PostgreSQL 8.1.3
> Win32 installer? If you are able to upgrade your database to PostGIS 1.1.2
> the latest Win32 installer at http://www.webbased.co.uk/mca/ contains
> shp2pgsql.exe compiled with libiconv support to enable the -W switch. More
> information about the upgrade process can be found at
> http://postgis.refractions.net/docs/ch02.html#upgrading.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it
> or
> use it for any purpose nor disclose or distribute its contents to any
> other
> person.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060519/1eb3e90d/attachment.html>
