[postgis-users] Google Earth/PostGIS integration
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Tue May 23 10:20:00 PDT 2006
Sure it is nice. I just thought it could be more easy do a postgis
connection with Google Maps. But how to connect (or just see) this bases ?
I have a desktopGIS with me and would like how to load a layer on Google.
Regards
Ezequias
Brian Timoney escreveu:
> Jim:
> With time a little short these days, I'll simply sketch out a few key points--
> 1) The viewbox parameters for Google Earth (bbox, tilt, heading, range, etc.)
> can be read by a server script (PHP, ASP, CFM, etc.) via a Network Links layer
> in GE.
> 2) Now that you have a handle on where the viewer is looking, how far they're
> zoomed in, etc., you can craft SQL queries to do perform geoprocessing
> operations (e.g. clipping), etc. Again, using server-side scripting, you can
> then query your PostGIS db on the back-end.
> 3) The Geometry specifications for Googles KML (Keyhole Markup Language) are
> very similar to the OGC's GML standard. So pulling geometry out of PostGIS
> using the 'AsGML(the_geom)' function gets you 90% home in terms of converting
> query responses back into KML.
> 4) Applying the appropriate MIME types to the KML you send out from the server
> will ensure that the receiving browser knows to shuttle the response to the GE
> interface.
> 5) Using GE's internal web browser (Windows only), is a handy way of keeping
> the user in the general "environment" even though technically the bulk of the
> data transaction is taking place between web browser and server.
> Hope this is helpful,
> Brian
> The Timoney Group
> 518 17th Street
> Suite 430
> Denver, CO 80206
> Ph: (303) 929-3722
> Fax: (303) 571-4304
> www.thetimoneygroup.com
> The Timoney Group
> 518 17th Street
> Suite 430
> Denver, CO 80206
> Ph: (303) 929-3722
> Fax: (303) 571-4304
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
