[postgis-users] Google Earth/PostGIS integration
TECHER David davidtecher at yahoo.fr
Tue May 23 13:55:47 PDT 2006
Hi
Did U have some interesting URL ( WMS->GE gateways) to give us for that.
Thanks
--david;
Craig Miller a e'crit:
>There are a couple of WMS->GE gateways.  You could use one of those to load
>the GE basemap as a WMS layer, then put the PostGIS data on top of it.
>--Craig
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net
>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ezequias
>Rodrigues da Rocha
>Sent: Tuesday, May 23, 2006 10:20 AM
>To: PostGIS Users Discussion
>Subject: Re: [postgis-users] Google Earth/PostGIS integration
>Sure it is nice. I just thought it could be more easy do a postgis
>connection with Google Maps. But  how to connect (or just see) this bases ?
>I have a desktopGIS with me and would like how to load a layer on Google.
>Regards
>Ezequias
>Brian Timoney escreveu:
>>Jim:
>>With time a little short these days, I'll simply sketch out a few key
>>points--
>>1)  The viewbox parameters for Google Earth (bbox, tilt, heading,
>>range, etc.) can be read by a server script (PHP, ASP, CFM, etc.) via
>>a Network Links layer in GE.
>>2)  Now that you have a handle on where the viewer is looking, how far
>>they're zoomed in, etc., you can craft SQL queries to do perform
>>geoprocessing operations (e.g. clipping), etc.  Again, using
>>server-side scripting, you can then query your PostGIS db on the back-end.
>>3)  The Geometry specifications for Googles KML (Keyhole Markup
>>Language) are very similar to the OGC's GML standard.  So pulling
>>geometry out of PostGIS using the 'AsGML(the_geom)' function gets you
>>90% home in terms of converting query responses back into KML.
>>4)  Applying the appropriate MIME types to the KML you send out from
>>the server will ensure that the receiving browser knows to shuttle the
>>response to the GE interface.
>>5)  Using GE's internal web browser (Windows only), is a handy way of
>>keeping the user in the general "environment" even though technically
>>the bulk of the data transaction is taking place between web browser and
>server.
>>Hope this is helpful,
>>Brian
>>The Timoney Group
>>518 17th Street
>>Suite 430
>>Denver, CO  80206
>>Ph:  (303) 929-3722
>>Fax: (303) 571-4304
>>www.thetimoneygroup.com
>>The Timoney Group
>>518 17th Street
>>Suite 430
>>Denver, CO  80206
>>Ph:  (303) 929-3722
>>Fax: (303) 571-4304
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>Ezequias Rodrigues da Rocha
>http://ezequiasrocha.blogspot.com
>msn:ezequias at hotmail.com
>"the worst of democracies is still better than the best of dictatorship"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060523/e9cd8a5e/attachment.html>
