[postgis-users] new user = new problems
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Wed May 24 08:52:35 PDT 2006
Matteo,
Try putting a full or relative path to the sql files like this:
psql -d yourtestdatabase -f ../share/contrib/lwpostgis.sql
psql -d yourtestdatabase -f ../share/contrib/spatial_ref_sys.sql
Regards,
Mike
matteo rossi wrote:
> Hi,
> I recently installed postgre 8.1 with postgis 1.1.2-1 for windows xp.
> I experienced many problems in following the steps suggested into the
> postgis manual uploaded in postgis site, especially about importing
> shapefiles, as it should concern other version than mine.
> The first problem if when I use the psql, the database created is NOT a
> spatial database but a simple postgres one.
> How I can transform it in a spatial one?
> How can I directly create a spatial database?
> I tried with
> |psql -d yourtestdatabase -f lwpostgis.sql
> psql -d yourtestdatabase -f spatial_ref_sys.sql
> but the "psql" command and the *.sql files are not under the same
> directory, so the shell don't recognize them.
> Can anyone help me?
> Thanks a lot
> matteo rossi
